Ford Dana 44 wheel hub interchange.
1sicbronconut
I'm out of spares and need to order a wheel hub for a Dana 44, parts houses show a different hub for 76-77' Broncos and 76-79 F150's or 78-79' Bronco's. I'm pretty sure I've used either for builds before anybody know what the actual difference is between the two. TIA Steve
thegreatjustino
Red Head Grease Monkey
Stockton, CA
When you do the Chevy Disc brake swap to a Dana 30 or drum brake Dana 44, you can use the hub and rotor assembly from a 1976 to 1991 Bronco. I've used hubs and rotors I pulled at the local junkyard from 80s/90s Broncos on my Early Bronco disc brake conversions more times than I can remember. This tells me they're all the same. My $0.02.
1sicbronconut
1sicbronconut
Thanks I figured they were all the same up till the early 90's or so.
