Ford Dana 44 wheel hub interchange.
1sicbronconut
I'm out of spares and need to order a wheel hub for a Dana 44, parts houses show a different hub for 76-77' Broncos and 76-79 F150's or 78-79' Bronco's. I'm pretty sure I've used either for builds before anybody know what the actual difference is between the two. TIA Steve
thegreatjustino
Red Head Grease Monkey
Stockton, CA
When you do the Chevy Disc brake swap to a Dana 30 or drum brake Dana 44, you can use the hub and rotor assembly from a 1976 to 1991 Bronco. I've used hubs and rotors I pulled at the local junkyard from 80s/90s Broncos on my Early Bronco disc brake conversions more times than I can remember. This tells me they're all the same. My $0.02.
1sicbronconut
1sicbronconut
Thanks I figured they were all the same up till the early 90's or so.
ntsqd
heratic car camper
Upper SoKA
When you get into TTB donors the spindles can be either the 5 bolt or the 6 bolt depending on the donor's year. Early are 5 bolt, then for a short time they were 6 bolt, then back to 5 bolt. '96 only has an odd inner bearing seal supposedly due to the ABS ring. Not sure if that affects the spindle's geometry or not, but it is a 5 bolt.
AFAIK all of the TTB wheel hubs, except for the '96, are the same.
jamesroney
Fremont, CA
What about the 1987 to May of 88 Bronco Dana 44 TTB with manual hubs? I know it used oddball hubs, but I thought it got a special spindle too?
ntsqd
heratic car camper
Upper SoKA
At this point I've seen nothing conclusive about those hubs, but I've not had a need to really dive deep either.
ntsqd
heratic car camper
Upper SoKA
That is very odd looking. Clearly a hub for those spindles isn't going to fit a "normal" spindle.
1sicbronconut
1sicbronconut
Odd balls for sure! Those used the "hat" style locking or auto hubs like the smaller Fords with Dana 28 and Dana 35's. If I remember correctly I converted a few of those because the parts were obsolete and you had to replace the knuckles as well. I actually found a spare out in the barn after all it was hiding in my stash of spare Dana 44 knuckles :) I actaully researched Dana 44 TTB's quite a bit when I did the 5x5.5" conversion on my 92' Explorer retaining the Dana 35 knuckles.
Steve83
...the hub and rotor assembly from a 1976 to 1991 Bronco.
The Bronco hub & rotor were the same from '80-92 (and maybe earlier - I'm not familiar with pre-'80) except '87-early '88 with factory manual locks.
When you get into TTB donors the spindles...are 5 bolt, then for a short time they were 6 bolt, then back to 5 bolt.
IDK how early the 5-hole spindles were used, but '80-91 are 6-hole.
'96 only has an odd inner bearing seal...
It actually appeared in late '95, before the '96MY.
...due to the ABS ring.
That appeared in '93; the seal is a separate factor.
Not sure if that affects the spindle's geometry...
Yes, the seal takes up some space, so the spindle has a step, and the hub is shorter.
(click this text)
No, '80-92 (exc.'87-88man) are the same; '93-96 have the surface machined for the tone ring but are otherwise interchangeable with '80-92; 5/95-96 use the double-lip rolling-diaphragm seal and are shorter on the backside.
Yes, the spindles & hub/rotors (they're 1 piece - not separable) are specific to that design. This is the hub/rotor that goes on the spindle that Toddz linked above:
...had to replace the knuckles as well.
I don't remember any difference in the knuckle or stub axle shaft; I think only the spindle & hub/rotor go with the tophat manual hub lock.
(click this text)
It's just a whole lot quicker, easier, & cheaper to scrap the whole TTB and put in one with the normal hubs.
