Ford factory tilt steering column from a late 70's Econoline full size van with an Auto trans. No key on the column. This steering column is barely longer than an Early Bronco column, or could be the same from measurements I took. I've read somehwere here in the past that an Econoline Van column is about the same length as an Early Bronco column.
It will have to be converted for EB use by swapping mount brackets from your EB column over to this. There used to be a write up here & elsewhere for this conversion.
Tilt mechanism appears snug, Auto trans shifts good, needs turn signal clicker replaced.
No steering wheel.
$300 obo + ship
No steering wheel.
$300 obo + ship
