Gravel Maker
Our FORD SMALL BLOCK MOTOR MOUNTS fit 289, 302, 351 Cleveland and 351 Windsor blocks. These are designed to bolt to the block and mount tabs to you chassis, they are not a stock bolt in replacement. The main bracket is made from 1/4" thick steel and use a 1.75" x .120 wall DOM sleeve for the bushing. The sleeve inside the bushing is 1/2" with a mounting width of 3" OD. They come unwelded so you can offset the bushing mount left or right on the base plate.
As you can see the bushing is completely encased by the .25" bracket making it possible to endure extreme torque!
http://www.ruffstuffspecialties.com...arch_Begin_Only=&sort=&range_low=&range_high=
