Ford Track Lock worth rebuilding?
jckkys
My limited slip has worn out and has no effect. I have no problem with the 28 spline axles and have no interest in fixing things that aren't broken. So far the only reasonable alternative I've been able to find is a true track.
The ARB would cost at least $1500 with me doing most the work. Thus not reasonable.
Can anyone suggest a traction device that isn't a pain on pavement like a Detroit locker, or cost a mint?
The traction lock was better than nothing when it was new but after about 20 years it became meaningless. I have no intension to run tires larger than 31". The need for a traction device comes up in snow or ice conditions in the mountains or climbing steep gravel trails. Simple 4-wheel drive handles the rest of the problems. But it's embarrassing to sit on level frozen snow pack with one front and one rear wheel spinning.
Skiddy
i have heard after they are rebuilt they work very well
red hot71
kent wash.
Before you invest money into the trac-loc make sure it's not cracked around the bolts that bolt it to the ring gear.
bronconut73
Is a Detroit True Track better than a factory Track-Lock? Yes.
Having said that the Classic Mustang guys swear by these Track-Locks. If you get a True-Track you will have no trouble selling the Track-Lock to a Mustang guy on Craigs List. I did and fast.
It's tough for me to say, "stay stock", but this is one of those stock parts that is pretty darn good.
AZ73
Detroit soft locker. It's not like the old days when they clicked around corners (Detroit Locker). You have to really gun it to get it to do that. I had the same decision you have. Went soft locker for back and true trac for front. Thought about ARBs, but I'm not doing a lot of rock crawling and I wanted something similar to LSD but fully mechanical and automatic. Didn't want to be manually turning off and on the locks. I'm not driving in snow and ice (a slight problem with a locker) and the true track will just spin a tire in the air (you can apply a little brake to help you through) I know some people who went the reverse (locker in the front because it's only engaged when you lock the hubs, and true trac in the back), and some guys that did true tracs front and back (nice video of a guy in a jeep going up a nice trail with them, and they performed well). They're not hard core crawlers. It really depends on what you'll be doing. For me, I wanted simplicity and automatically engaging for mostly road and desert/sand driving. I did a lot of research and watched countless YouTubes to see what people were doing and how they performed (mostly in jeep forums) to see who was doing what I wanted to do and how their set-up performed. Think about what you want to do, spend a couple of hours looking at videos, and then decide.
Rustytruck
first I would start with one of these.
http://www.ebay.com/itm/9-Ford-Bill...903&pid=100011&prg=1036&rk=1&sd=220854293388&
Then I would rebuild the unit. It would probaby come pretty close to the trutrac unit price wise. I have a trutrac in the front of my Bronco and I think its the best thing going unless you need a tru locker.
If you do this yourself mark the teeth in the pinion gear and the 2 teeth on the ring gear so you put the 2 back together in the same place. Check your current backlash with a dial indicator. then after you put the carrier back in and get the teeth set in the same spot you can just set the backlash back where it was and everything should work fine. If you pull the pinion gear you will have to reset everything up from scratch.
J
jckkys
The traction lock worked fairly well when new and since all the main parts are there a rebuild should take care of the rear,without breaking the bank. For the front my local differential shop recommends the power lock. I don't think I'll ever wear out the front differential. My biggest concern was feed back through the steering but I was assured the power steering gear takes care of that.
spap
If you go Detroit locker the 28 spline axles will be a weak link.
John Marinan
Durango CO.
Check online I picked up a Trac Lok on ebay for $300. It's a 4 pinion that came from a 66 Galaxy and was in perfect like new condition. It could take a little time to find one but they made around 2 billion give or take.
J
jckkys
When I take a trail I'm trying to get somewhere, or back out. I don't try to twist the truck into some bazaar contortion, or get it stuck in mud or snow just to see if I can. Did that 40yrs. ago when I bought my first Bronco. I was stationed outside of St. Louis and walking out never took more than 1/2 hr. Scouting for elk in northern Az. is very different. I saw some trails near Moab I wouldn't even think of doing. It was 600mi. from home. That said a near stock Bronco can do some amazing things and unlike my buddy with a Land Rover I never broke an axle. He seemed to break a lot of them. But my 28 splines with traction lock did fine. The differential shop can rebuild the center section reasonably and I'll do the rest, except welding a WH wrap trap on. Wheel hop is the only other problem I've had with the rear end.
The more aggressive lockers are more stressful for the axle so are bigger tires so I think I'll stay more conservative.
I've found an open differential works best on hard packed snow but again the ARB is too pricy.
broncnaz
Trac loc is worth rebuilding yes its not the best but it works when new should last at least 50K or more. I've never had a issue rebuilding one and not having it work afterwords. Like you I've had pretty good luck with how the trac lock works I think most of it is knowing how to drive half the people dont know how they just put a locker in so they dont have to pick a line. I've gone a lot of places with just the rear trac loc and 2wd while others are in 4wd and struggling right behind me.
Currie Ent. sells all the parts you need. Get the clutch plate and steels kit along with new preload springs and some shims. I would also suggest getting new thrust washers for the side and spider gears as your already in there and can easily replace them.
As for the rebuild well keep or at least measure the orginal shim/shims then replace with the same or shim it up a little more and you'll be good.
Now i also agree with getting a 4 pinion unit they are much stronger I've broken 2 two pinion setups. Might want to check the pick and pulls I've gotten complete third members with trac locs of $80
J
jckkys
It's always amazing how some drivers can make an easy trail difficult. 21 yrs. driving a bulky 2 wheel drive UPS truck taught me to avoid a bad line even if it means walking it first. We got some rain last night so today I'll see knuckle heads driving 4x4s around Tucson with a mud covering their whole truck. You have to look hard to find mud here.
Went through a junk yard yesterday and found a stack of 9" rear ends. I'm sure I can find some with the "L" on the tag.
broncnaz
If you find one in a van it may be a 28 spline model last one I scored was out of a late 70's van 28 spline 4 pinion. Only small issue was the 3.25 gears it had. Also some 60's-70's pickups also had 28 spline rear axles
