GRIZZLY
There is a write up on the new Bestop in the latest Four Wheeler. Since a lot of us have old Kaylines I'd like to point out a few tips on taking care of your top. There are several photos of problems they were having with their older top. If you occasionally swab(q-tip with a little WD sprayed on) your snaps with WD-40 you lessen the chance of this happening. If it does, don't try to yank it apart or you will rip it apart as shown. Use the edge of a knife to pry in between the two halves' seam to separate it(then replace or WD it). They showed a photo where the wing nut that holds the upper back corner of the door frame had worn through the top. The wing nut should be on the back side of that joint(facing into your interior) and never touch the top. They had duct taped the top to the door frame because the velcro wore out. Replace the velcro. My top is almost 8 years old and has had the windows replaced twice(once because of stolen speakers from the former owner), new rear tensioning straps sewn on, and several snaps replaced, and still fits tighter than the new Bestop they show. If the Bestop is your choice by all means go for it. It's a nice top. Just remember that the better you take care of it the longer it will last. The biggest no no is getting dirt or sand in rolled up windows. When I finally replace this one the main material is still in good enough shape to turn it into a full length bikini.
