Front Bump Stops on the Frame
JohnJohn
Richmond
My 37's are hitting the wheel wells even with a 3.5" lift when I go over big rocks. I am running stock bump stops on top of a track bar riser on the passenger side and in the stock location on the drivers.
I am looking to buy a 4.5" aftermarket bump stop but mount them on the frame vs. on the D44.
I was thinking a rear set that has the mounting tabs on each side vs one bolt in the center would work.
Is anyone running the front bump stops on the frame?
Any pics?
Seventee
In the sticks of MT
I swapped to a HP 44 which does not have bump stops. So I took a couple pieces of 2-1/2" box tubing and welded to the underside of my frame. Then took the OE bump stops off my Dana 30 and bolted them to the underside of the box tubing. Works good for me running 35s and 3-1/2" suspension lift. You could vary the size of the box tubing to achieve different stop heights.
Now granted you could also use aftermarket stops to achieve the same thing, but I'm cheap. ;)
jmangi62
I still need to install mine,I bought the 4" poly ones with the single bolt for the frame,haven't installed anything yet but was going to do the same for the rear,5.5" suspension lift,D44 low pinion swapped in.Also interested in how guys are installing these. :cool:
Crush
Greenbottom, WV
Duffs sells anset for the front like you are wanting. Comes with two stops and 4 self drilling/tapping screws
eBronc2
I swapped in a full width high pinion D44, for bump stops I used sections of 2"x4" rectangular tubing about 4.5" long bolted to the bottom of the frame rail as spacers, with Energy Suspension pyramid shaped urethane bumpstops bolted to the bottom of the tubing. I had to drill and tap holes in the bottom of the frame rail to bolt the tubing to, got "lucky" and one of the holes turned out to be right where a factory rivet was, those things are harder than the hinges of hell, went through numerous drill bits and lots of interesting vocabulary.
I cut down old leaf spring axle brackets and welded those to the axlehousing as landing pads for the bumpstops.
garberz
Bronco Influencer
Conejo Valley, Ca.
D44 HP has no provisions for bumpstops in factory location. I used coil spring inserts.
Mark
AxlesUp
Collierville TN
looks like they classify them by how many rings they have
i saw:
2,3,4,6 and 8 rings.
i just read an article by a jeep guy that desert races and he cut his down to size as well.
garberz
Bronco Influencer
Conejo Valley, Ca.
I'll have to take some measurements.
Mark do you have any insight?
They compress a lot, so they're not actual stops. They work fine for low speed crawling. They add to the total spring rate and have zero rebound energy. At ride height I have 2 1/2" of travel before they contact. I made flat pads for them to set on and hit up top. I have a total of 12 rings per coil. I didn't cut them, just stacked em'. The distance from the top of the insert to the bottom of the coil spring mount was figured by the heights of the flat pads I made.
For higher speed stuff, I'd still like something a little more of a positive stop. Like Daystar bumps or air bumps ($)%) Eventually.
Mark
