front bumpstops w/ WH's track bar riser??
blazinchuck
hey guys, show me what you've come up with since installing a track bar riser(mainly the WH's riser) not interested if you made your own riser or using another brand-
been wanting to install some bump stops, but the pass side doesnt have a way to mount it since the riser stands up so tall...
any pics would be great...thanks,Chuck
blazinchuck
blazinchuck
i have a couple diff bump stops, but 4 are for the rear...and so far i can only find one of the fronts. the bump would over hang the stock mount on all sides...so with the riser in place, it wont fit now. when you say trim...you mean the metal plate the stop comes mounted on?
thanks for the replies
stupidboy
My wifes porn star.
Morrisdale Pa.
Wild horses 4-1/2" bump stop for the front, trimmed to fit with the riser, plat and rubber I suppose. I'll be having to do the same thing. Look at your new WH catalog.
bronconut73
I heard somebody say they just kept walking back and forth to the bench mounted grinder. Grinding both the plate and the bushing at the same time. Eventually they had it trimmed smooth and perfect.
motoman
Phoenix, AZ
Maybe you could cap the top of the riser to use for a bumpstop. 70_Steve built his and mine plus raised up the driver's side to match.
Passenger bumpstop
Driver's side raise
Sorry I know it's homemade but thought it might inspire some ideas.....
blazinchuck
blazinchuck
the bump stop should limit up travel so one does not hit axle to oil pan, tires into fenders,etc...im only running 3.5" lift. with WH flares...i can allow as much as i can, but want to limit it. i dont have room to add some tubing that tall on top of my original mounts. I may just go back and do what i did on fat bottom girl...the only thing i would do differnt-NOT USE those pointy little bumps like in the picture posted. every time they hit, it will knock your teeth out!! plus if they hit too hard they will bust and fall off! i found this out in Harlan couple yrs ago. ill be using the progressives only...i want something to sloooooow up travel
Oildog
AJ
I'm running a Protofab raised track bar mount on my rig, probably about the same height as the WH bracket. I used the progressive bumps on my axle and just cut off all but the last loop of poly on my passenger side bump so I'd have at least a little bumpstop dampening there; it's bolted to the top of the raised track bar mount. I lose a little up travel on the passenger side compared to driver but it doesn't seem to impact my wheeling too much...away from my rig for several days or I'd snap a picture for you...
motoman
Phoenix, AZ
That just makes it so you don't have all the available flex does it not?
The bumpstop height is at full spring compression minus a bit..... so shouldn't lose any compression. Gonna get it on the ramp in a couple weeks at the AZ Classic Bronco stampede to verify.
broncosbybart
Chuck, I've done it a few ways. You have to remove A LOT of material from the front of the bumpstop in order to get it to fit the factory hole.
My solutions are as follows:
1- drill a new hole further back for the bumpstop anchor bolt and grind a bit off the leading edge (front) of the bump stop
2- weld some 2" square tube above the factory mounting point with a new hole drilled further back and run a small 2" or 3" bumpstop. Of course by doing this you'll need to do both sides.
I've done it both ways with good results but do like the 2nd method better, especially if the axle is installed in the vehicle, as drilling a new hole would be just about impossible. I drill the hole in the square tube first then weld it into place.
