I know you didn’t ask this, but I’ll add it anyway…
When you tighten the caps with the new c-bushings, make sure the arms are the same height/angle when fully tightened. I always set the D44 on jack stands so the housing is in a fixed position off of the wheels. I then tighten the c-bushing cap bolts using an “X” pattern. ( see the arms rise and drop as you tighten the tops and bottoms.). When you’re finished, the arms need to be at the same angle/height or you’ll have “Bronco Lean”. I fine tune the arms using the stud to ground measurement as my reference standard - you may need to loosen an arm and restart to get them to match angle/height. This is an important step in front end assembly!
