The high pinion dictates the reverse bevel cut gears anyway, they go together.
So what can you expect if you do this? It will work, at least at trail speeds. Easy enough. But if you start cruising the highway some odd things can happen. Since the high pinion is designed to be a front axle you will be driving the coast side of the teeth. I can envision some oiling issues of keeping the pinion bearings lubed. Highway driving places different loads on the bearings compared to trail riding. Trail is low speed, higher stress where highway is high speed and moderate stress. The pinion is above the oil level. Lube is pumped by the ring gear flinging it around. Most axle housing have a channel on the top of the case that lines up with the ring gear to feed oil into the pinion bearings. The pinion is going to be blocking that oil flow I am pretty sure. At least something to look into. At trail speeds you don't have to concern yourself so much with oil flowing to keep bearings alive, just keep parts wet so they don't gall.
