front door post replacement
xeasyriderx
Stanley
I need to replace the front door post/supports and the fact that I'm not a body man; how do you replace these in the proper location? It seems to me that would be detrimental to the proper alignment of the door and fenders. Looking at mine, I can't see what it is that they weld to. It would be great if there was a exploded picture book that told dummies like me how these things are assembled! Every other part seems to make sense, but these just seem to be out there supporting the door in perfect alignment and attaching the fenders to line up. I figure if I screw this up, it will just get worse as I go.
Anybody got a copy of that book for dummies???
904Bronco
San Martin, CA
There is no book, just knowledge shared here from years of experience...
Spot welds, a whole lot of them...
Yes one of those things that if it is welded in out of alignment, it will mess up many other things. I was a 1st timer to door posts, but had done floors and such a few times before. One side at a time, take many pictures on how things looked B4 you take it apart. Be prepared to find more hidden damage.
Treat the rust you find, replace what you have to. Use weldable primer paint, seam sealer, and... many other products... Do you have a welder?
There is a thread for my door post replacement and I looked for and read through other B4 tackling mine.
You cut out the old, positing the new with sheet metal screws, hang the door and fender to fitment. Then weld in place slowly.
At times it is finesse, and other times it is a block of wood and a BFH
I am really over simplifying this...
