blubuckaroo
Grease Monkey
I installed a NV3550 kit a few years back, and noticed something now when servicing the front driveline. I typically pull the drivelines out so I can grease them properly. The bolts and grease fittings are just about completely covered by the transfer case/transmission cross member.
I may end up putting a jack under the tranny so I can remove the cross member. All this just to grease the double cardan joint.
Has anyone else run into this?
It's good I don't use 4WD much.?:?
