- Nov 3, 2003
- 48,462
My bronco doesn't really have a year. Everything is brand new, except the radius arms and the front end housing. It's titled as a 71, but it isn't. All Mod not much Resto.
Ah yes, I seem to remember a recent comment about a "Johnny Cash Cadillac" Bronco coming together.
That was you maybe?;D
Frame is Kincer
Stock height radius arm brackets? Or do they modify them (longer) to create some better geometry? Never heard that, but curious if that's part of their thing.
front end is the Dana 44 full set-up from Tom's, comes with disc brakes.
Ahh, custom brand new stuff, eh? I wonder if they build extra caster into them and have the pinion and radius arm bosses dialed in for lifts already?
I'm not familiar with their diff housings, but I'll go to their site and check it out for more details.
The 7 degree was suggested by WH precisely for tracking, I didn't have any input on that side as I don't know enough to have an opinion, though that rarely stops me.
Haha! Yep, understand. And yes for a mostly street Bronco more caster is good even with minimal height change, if any. But we can still run afoul of the pinion obviously. It's frankly not very often, but that does not help here unfortunately.
Might be time for a punt, or even a Plan-B.
We'll see how it goes with your tests, but I bet at least some of it comes back down to the angle.
Be nice to dial this aspect in for sure. But it pays to be certain. I remember how many NV3550's had to be replaced because they were "noisy" when it actually turned out to be a rear driveline misalignment (from the lifts) sending a harmonic right up the shaft, through the much tighter transfer case, and into the much looser 5-speed trans. Never had that issue with stock 3-speeds, but the NV was a real death-rattle trap when that vibration hit it.
