front driveshaft rub
bluebronco69
Damascas, OR
my front driveshaft rubs on my duffs headers, anyone have any problems with this too? i have a d44 and stock driveshaft, i dont think the axle is centered because i have about 2 inches of lift and no trac bar adjustments. so the axle is moved over to the driverside a bit, is that causing it maybe?
thanks
josimps2
thanks
I had the same problem with my Duff Header's. I've got a stock 74 uncut with no lift. When I first put the header's on they would rub on the front driveshaft when I was making sharp turns, traveling down hill, or hit any sort of bump. It didn't do anything to correct it. I just continued to drive it until the driveshaft beat the headers in and out of the way. I know it's not the solution you were looking for but they don't leak and don't rub anymore. I'm not real concerned with how the look, considering everything else is rusted.
bronconate68
Vancouver, WA
I have the duff's 3 1/2" lift and my front drive shaft rubs. I'm going to grind the flange down to create more room. I've already grinded some but not enough.
I would like to know what the fix for this is also. Must be a lot of front drive shafts rubbing.
68 Broncoholic
WA
You need an adjustable trac bar or drop trac bar bracket to center the axle. Using an adj drag link will also help center the steering.
My 74 was close also so I got the pry bar out and bent it 1/2" further away. Now I have 1" clearance which seems to be enough. Probably not the best option but it worked. Plus it was 1/8" from touching the D20 also, not its 3/4" away.
RangerRob
Had a friend (Willie) run into this same deal. Duff told him to heat up the headers and bend them out of the way. Did just that with a C-clamp and 3000 rpm for a few minutes and it worked fine. Let things cool down while the clamp is still there.
Good Luck!!!
:cool: :) :cool:
bronconate68
Vancouver, WA
I never thought about bending the header when it's hot. Guess what I will be doing after/durning my next run.
My axle housing is centered. The drive shaft rubs the header flang when I have a little flex on.
kontinu
mount holly
I had the same problem, I got an adjustable trac bar and that centered the axle back up. It's also good incase if I go bigger with my lift. I can just adjust it again!
