Front Driveshaft Too Long????
Mikey
I just got a used front driveshaft in and I am having trouble installing it. I installed the CV end first and now the shaft wont collapse enough to clear the pinion nut/bolt. Do you have to install the CV end AFTER the U Joint end? Also, if it's that close, is something wrong? How much space on the splines should it be?
I have a 74 with a 2.5 inch lift.
I'll check the collapsed length when I get home this evening and see if it's 22.25". The one for the Dana 30 is 23.313"...perhaps this is what I got?
The PO deleted the CV so I'm fixing that problem and have nothing to compare to. Pics would help!
Thanks,
Mikey
GRIZZLY
Lakewood, CA
Your drive shaft half should end up midway through the splines. Measure from the flat of the cv yoke to the center of the u-joint yoke to get your static length. If your shaft is too long it can be a real problem. The one benefit is that if it is too long you should be able to take it to a drive line shop and have it shortened to the proper length and rebalanced without having to buy any material. If it was too short they'd take your existing components and put them on a new shaft.
blackjack
San Diego
drive shaft
You probably have a Dana 30 drive shaft they are longer than the Dana 44 Drive Shaft. If you had a 5 1/2" lift you could use it but you will just have to get something else or have it shortened like Dennis mentioned..
Hope that helps...
M
Mikey
I'm working with the guy who sent me the driveshaft. He has a bunch of shafts out of a 74 and says they are all measuring the same....just under 24" from center of outer cap of CV to center of U-joint! Spicer shows this is supposed to be 22.25" I don't get it! Anyway, he has one that's around 21" that came off another 74 that should work. We are both at a loss.
I did the Chevy conversion so it has to be a Dana 44 plus, doesn't the yokes differ as well? I can get each end hooked up it's just simply too long!
We are figuring that Ford did a run of something that was odd. I work on old Cougars and 5.0s and Ford sometimes deviate from the norm to use up old parts.
Here is the link to Dana Spicer pdf showing all the specs...it's 2 megs to download!
http://www2.dana.com/pdf/J321-CV.PDF
Thoughts? Insight? Help!?!
Thanks,
Mikey
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
The chev brake convetion fits the D30 the same as a D44.
The yokes on the diffs were all the same.
The T-case yokes were smaller on '66-'68s and maybe '69 but it's very common for people to upgrade the yokes when replacing the drive shafts.
'74s never came with the D30 but it would have been very easy for a PO to swap one in.
None of this explaines the diffence in measurments your seller has tho.
M
Mikey
Ok, per this link....
http://www.broncohio.com/tech/dana30dana44.html
It's definitely a Dana 44.
Sooooo....still stuck. Anyone with a 74 and 2 or 2.5 inch lift want to measure yoke diff flange to transfer case flange for me for the front driveshaft? Then, I can check mine to see if mine is odd or if the shafts are odd.
Thanks,
Mikey
