front end shaking
blackjack
San Diego
What would cause front end shaking at lower speeds like 25 to 30 when you hit a pot hole. I mean some serious shaking from the side you hit the pot whole on. Is it my track bar bushings or my knuckle boll joints on my Bronco. It has to be one of the two, I know everything else is good.
Thank you for any help.
mrcat88
VacaVILE, CA
track bar bushing is first to check....it's more likely to be the bushing, it's cheaper, and it's easier to check. Next go for the ball joints....nothing like a good joint....er.....whoops..... :eek: ;D ::)
Mrcat88
sicaz66
san diego
mine did the same.ended up being when i did my lift i needed a drop trackbar bracket. did you just lift it?
Hnrys69
Track bar bracket has worn out... Mine did the same thing. Check the upper bracket and see if where the bolt goes through is oval... Mine did that super bad so I went to a drop bracket and problem solved because the hole was round again :)
flousberg
Check the track bar bushings and don't forget the check the rear radius arm bushings, did the trick for me. ;D
