Front spare tire mount
BajaBronco
Does anyone have a front spare tire mount or has anyone heard of such a thing for sale. I'm not going to be able to carry a spare inside or outside on the rear of my Bronco, but would still like to have one handy. Anyone have any ideas/recommendations on alternative locations. I really dont want to do a landrover hood style mount.
greasypigeon
Fort Bliss, Tx
The biggest I have seen on some ones front is a 32". If you have heating problems then you might want to put it on your roof, cause the tire will block the flow of air.
BajaBronco
BajaBronco
Good point guys... It's a 31" on a 15x8. I wont have a roof either, so I think it's gotta go up front....just wondering if theres something out there to buy or maybe best would be to modify an old pushbar?
Louie
If you put a receiver hitch up front you could buy one of those hitch mounts.
Carl
Aurora, IL
It seems like it would be easy enough to fab something up if you know how to weld or have a friend with a welder. I'm surprised no one has done it before. It would be cool to see a front mounted spare on an EB.
NorCalBronco
What about on the rear passenger quater? Some broncos had a mount there stock, it used the normal swing away thing yet mounted the tire on the opposite side and bolted it to a bracket on the rear passenger quater.... I cant seem to find a picture though.
edit... found one, thought not the best picture.
broncnaz
I wouldnt put it in the front it will block to much air. I'd find a way to mount it out back. Why cant you do a rear mount? the reciever hitch idea would be fine for the rear also. Might be able to do mount in the bed that puts it on top and out side the quarter panel but thats a lot of stress on sheet metal.
Skiddy
My dad had one on the front of a 69 chebby, was a U shaped piece of tubing
needabronco
Prescott/Farmington
I had a 74' Chevy, with one, if I remember right it was mounted to a triangular bracket of channel steel that was bolted to the bumper and braced to the core support. I never had any overheating problems in the AZ heat with it either.
johnmlebel
same basic setup ushape channel triangle plate po said it never over heated while working in the woods with it
BajaBronco
BajaBronco
I got one of those Four Wheel Campers for my 72 and am taking a road trip with it, and thats why I was thinking front mount. Just trying to prepare for it, but it's still a couple states away, so I dont have it for reference. Since the top pops up, I'm thinking it shouldnt' go on the roof. And the tailgate is down...and the sides stick out, so I think the side mount tire rack wouldn't work. Outside of tailgate, hanging down might work....
broncnaz
Another reason for not putting it in front if you have a camper you have to haul around that is more load on the engine and you need all the airflow you can get. Other vehicles may not overheat with a front mount but most of them have radiators that are way bigger than the bronco radiator so its not much of a problem for them. Maybe a extended mount on a rear reciever hitch so it clears the tailgate might be your best bet might even want to build it with a rack for a cooler.
BajaBronco
BajaBronco
Yeah, I got a fridge inside, so I think i'm okay on the cooler issue. The door is back there too...hmm... I might play with a tailgate center mount that hangs down like a Toyota p/u.
22213evl
Rio Rancho N.M.
bolt a plate (in exitsting holes) and put it up on the side
ratchet stap to roll bar. non pemanent,easily removable,
20 mins to make. mine used to be there but it wouldn't fit in the
garage with the tire there so now it's an air tank holder
66Bronco
Herre's a front tire mount on a '66 Bronco.
Here's on mounted on the side
-Terry
BajaBronco
BajaBronco
ohh- I like the front mount. I need some trailer mirrors like that too.
Rumpfy
San Jose, Ca.
It's kinda hokey...but couldn't you put the tire inside the camper while on the road, and take it out when camping?
As a last resort cheap solution anyway...
