front upper adjustable alignment caster ball joint
broncozx
Will these fit our axles ?
https://www.carid.com/dorman-premiu...-caster-camber-ball-joint-mpn-bj811135pr.html
I have a -77, with a -72 axle, 3.5" sl, 7 degree c-bushings, raised track bar mounting, rockproof steering arms,
i have +2 degree on one side and +4 degree on the other side, of caster
it seems like i have to use the screw in type of caster bushing,
https://www.carid.com/1970-ford-f-2...lignment-caster-camber-bushing-537109845.html
but the most i can find is 1 degree.
i was hoping for at least +4 degree at each side, preferably more.
thank you
Timmy390
Conway, AR
thank you
Think you need these type....
https://www.spcalignment.com/index.php?option=com_spc&task=part_description&pid=23012
I know NAP has a selection of these......not sure if they had any 2 degree or not
Tim
