- Jan 11, 2017
- 1,292
What did I do wrong? I put my front axle back together this weekend from replacing all the seals and bearings. Driver side is all good but passenger side clicks when I put the hub lock out on. Everything went back in where it is supposed to go, down to the ring clip holding the guts of lock out in and when I push the outer cap of lock out in it clicks when you turn the wheel like it is slightly pushing in to lock the hub. When I lock it there is no click when turning the wheel. Did I not get something tight enough inside? I torqued everything down I thought.
