fuel filter placement
green73brc
where is a good place to put one of those big see through filters... the closer to the gas tank the better like a pump???<br><br>also what size is the fuel line i forgot to check and I wanted to get the stuff before I get home....<br><br>thanks
J-DUB
Edmonds
I placed my fuel filter is right before the pump in the engine compartment, that way its easy access and easy viewing.
Outshine2
Orange County, CA
Mine is between the pump and the carb, never had any problems with it there and it's very easy access. I could see how it might be beneificial to have it before the pump though. I believe the fuel line is 5/16 (least that's what it is in my 75).
Krusher
Brookhaven, MS
Got mine after the pump, sits right above the right side valve cover on a bracket I made. Also have a canister style filter on the fuel lines from both tanks, before the pump to keep trash outta the pump. Might be overkill, but they're cheap insurance. You can kinda see the clear filter on mine in the photo gallery on page 53, 1 up from the bottom I think.
Jeepster
Put it where you can see it. Thats why they are clear. ;) ;D
72bronco
I have two fuel filters, one before the pump and one after. Both are clear. I'll try to take some pics this weekend to show placement.
markcberry
Oklahoma City
[quote author=72bronco link=board=5;threadid=12900;start=0#96924 date=1041640373]<br>I have two fuel filters, one before the pump and one after. Both are clear. <br>[/quote]<br>I had a problem with with crap from the rear tank clogging my fuel pump and starving the carb. A clear filter before the pump is a cheap fix until I can get an aftermarket tank.
