Fuel Injection cutout problem
CupricReki
Grand Junction
For about 6 months now, my bronco (302 w/ EFI off of a 86 Crown Vic) has been randomly cutting power to the fuel pumps/eec relays. I checked all the connections at the relay, and found two weak spots and fixed em both. I even replaced the key switch. Whats strange about this problem is, i have the relays set to engage directly off the key, without the engine running, and the key in the "on" position, the fuel pumps will never cut out. But as soon as i turn it on it will either run for a little while, then just cutoff all power, or it will just send power when the key is in the "start" position, then cutoff all power when it returns to "on".
The problem as progressively getting worse and worse, up to the point were it wont run at all or, runs completely fine, or it runs really rough. I should add, that in the past, if i was going down the road and it just cut all power, i could just let the rpms go down and kick over the starter and it would restore power. Also, it seems as though the only effect systems are the efi and the pumps.
~Im off to do some more troubleshooting, but ill be checking back within 20 minutes
~Skyler
*edit: i forgot to mention that i pulled a code 87 off the computer: "Fuel pump primary circuit failure. When the FP relay was activated by the EEC, voltage was not detected on the control circuit."
CupricReki
CupricReki
Grand Junction
Fixed
After a ton on troubleshooting, it just turned out to be a loose nut on the starter solenoid (were the relays get there key power).
