Fuel Pick up location frame mount pump
Cmaxx252
Bakersfield
Im replacing the fuel line from the 23 gal tank to the carb. The previous owner had it hard piped in from the bottom of the tank (see arrow #1).
On the tank is it painted 'fuel pickup" (arrow #2) in a higher location.
Is this location suitable for a gravity feed frame mounted pump like the ones Tom's Bronco supplies?
I tried finding a diagram on the internals of that fuel pick up location. Is there a dip tube?
I searched for previous posts.. if I missed one already detailing this please tag it and I will research there.
Thanks Gents.
Cody
904Bronco
San Martin, CA
I have always treated #1 as a tank drain... 1st time I have seen it as a pick up point?
There should be a pick up tube, but then again you never know what previous PO's have done...
Any idea who built the tank?
Doug.
Cmaxx252
Cmaxx252
Bakersfield
Hey Doug,
My father is the one who put the tank in. Its the Kit from Tom's Bronco (23 gal tank).
That low point seemed like it should be a drain to me also. And.. kind of in a vulnerable spot to have plumbing, or a fuel pump that low. I was searching for other users you ran their plumbing from the tank forward to get an idea of another way to do it.
Cody
904Bronco
San Martin, CA
Cody,
If you know when approximately the tank was installed, then I would think a call to Tom's to verify if that Era tank has a pick up tube...
I would assume it does, if so use that port for the fuel pump supply.
lars
Been here awhile
NorCal flatlands
That looks exactly like my NWMP (North West Metal Products) tank. Pickup location with shroud covering it, drain location, labeling, etc all identical.
In the case of my tank, that pickup tube extends into the tank, then bends sharply down and ends within 1/4" or so of the bottom. Functionally it shouldn't matter which one you use except the tank drain port will have a slightly higher chance of sucking out and debris in the bottom of the tank.
Cmaxx252
Cmaxx252
Bakersfield
Thanks Gents.
Lars, you're right on the tank manufacture. Wild horses use to carry them. I just called my father to confirm again and asked if it was toms or wildhorses (foggy memory) He said wild horses actually. Are you using it with an efi setup or frame mounted fuel pump?
I'm going to try to port that is labeled fuel pick up. I planned to run two filters, pre and post pump but would rather not use that lower pickup point, One keeping trash out of the pump and not having the lines so low right behind the axel.
Thanks for the info and help guys.
Cody
ntsqd
heratic car camper
Upper SoKA
You'll want to be very careful about flow restriction in the suction line. Doesn't take much to cavitate the pump, which may as well be traditional vapor lock for how effective it is at stopping you in your tracks.
On one project I knew that it didn't have a strainer on the end of the pick-up (the OEM didn't make them that way) so I built a "filter" from SS wire mesh for an Aeromotive filter housing that was about 100 microns (as a guess). I did this to screen out the big chunks, but not be a restriction in flow.
On another (street car) project I knew that it did have the fuel sock, so no prefilter, but I could not place the pump as close to the tank as I'd have liked, so I placed it very low. That meant that there was always a head on the pump.
Seriously consider modifying the tank to put the pump inside of it.
Cmaxx252
Cmaxx252
Bakersfield
Exactly. I know the frame mounted low pressure pumps are not perfect for creating vacuum, and more head pressure is ideal.
I also didn't want to risk having the pump or line torn off if it were plumbed into the "drain" location.
I will go with a lower micron pre pump, element replacement filter downstream of the pump on the pressure side with an inline micron near the carb.
Thanks ntsqd.
ntsqd
heratic car camper
Upper SoKA
I'll also suggest that you set it up as a return system. There's a variety of ways to do this. Holley makes carb pressure range returning fuel pressure regulators. I have used one with a ~15 psi "TBI"-intended Walbro inline fuel pump even though Holley says it won't work. It did work for the ~4 years that I drove that car, and AFAIK it is still working for the new owner at least 3 years later. For a lower pressure, lower cost approach both Chevy & Jeep used fuel filters with a return port in them (NOT the LS swap "Corvette" filter/regulator).
The idea is to keep the fuel moving and not saturate in a hot spot because of low demand. Some guys put the return into the fuel filler neck. I've yet to figure out any reason to not do this if the tank doesn't have a return port.
Cmaxx252
Cmaxx252
Bakersfield
Interesting. I hadn't thought of doing that on a carb set up, but will look into it now. So you can still regulate pressure down at the carb to ~6 psi. but back at the filter with a return port, whatever isn't being moved towards the carb is circulated back to a return port or filler neck inlet into the tank. Is that the cliff notes version of it?
lars
Been here awhile
NorCal flatlands
Thanks Gents.
Cody
My tank has exclusively been used in an EFI setup. For the first 24 years with a frame mounted pump. Two, actually. A Carter P4594 rotary vane pump feeding a Bosch high pressure pump. Had a pre-filter on the tank output upstream of the Carter, and a 10 micron filter between the HP pump and the engine. The idea being that the Carter can pull fuel uphill well, whereas the high pressure pump is lousy at that but can push well.
The Carter pump could suck the tank dry. That model has been discussed extensively here, they work well and are durable. They are intended for carburetor applications. It did what I wanted it to do, but I reached the limits of that system when I swapped in the 408. The new engine requires a LOT more fuel at WOT, and the Walbro GSL392 high pressure pump I installed could outflow the Carter pump. I finally got tired of wildly dropping fuel pressure on hot days with low fuel tanks and switched both tanks (I'm still running an aux tank) to in-tank pumps, getting rid of all the frame mounted stuff except the filter. Problem solved.
If you remove the fuel level sender from the top of the tank you'll be able to see the pickup tube, which is just a piece of tubing with a slant cut at the bottom- no filter sock or any such thing. Put a filter downstream from the supply port and you'll be fine in your application.
Honestly if you use a Carter rotary vane pump with pre and post filters I think you'll be just fine. Simple. And I happen to have a brand new, never been out of the package P4594 pump that I can make you a very good deal on. I was planning to use it for troubleshooting my previous system when I was still in denial about needing in tank pumps, but then I finally got over myself and now it's just sitting.
ntsqd
heratic car camper
Upper SoKA
That is almost it. As I understand them those filters are the point where the return starts, not ends. They bleed off some fuel and send it back to the tank via the small tube.
Can see how I did it in these pics of the Valiant:
Walbro GSL395BX pump on the frame rail, length of rubber hose kept to a minimum, all hose is "Emissions barrier" hose on "Push-lock" fittings.
Filter can barely be seen at the bottom, is a Wix 33481, but an ACDelco GF481 works as well. These use an "O-Ring Bump" type of fitting, I used adapters to -6AN with Push-Lock hose ends. I use one of these: https://www.summitracing.com/parts/crt-a68301 in the fuel pump relay's control circuit. For the pump to run it either needs oil pressure or to be cranking. Can sort of see it in the plumbing on the firewall.
All of that said, if you are going to use one of the Carter P4070 type fuel pumps you shouldn't need a regulator unless you want one.
If you're going to use a Walbro GSL395BX or similar then you will need a regulator.
Either way, I'd use the 33481 or GF481 filter. They are EFI compatible (4 micron), rated for 300 psi, aren't huge, and are inexpensive.
Cmaxx252
Cmaxx252
Bakersfield
Thank you sir. Took a lot of notes on this one.
Cody
