- Jul 29, 2007
- 1,100
Bronco is EFI with carter P4070 low pressure to BC Broncos accumulator then to ford high pressure frame rail pump. I have burned up 3 low pressure pumps in about 5 years . The high pressure won't suck through the low pump maybe because of the accumulator ? I am tired of getting stranded so what do you thing is causing the low pressure pumps to go out? I am thinking about doing away with the accumulator and low pressure and see if the high pressure pump will pickup gas and work alone. Do I need a pacific high pressure pump? Thanks for your ideas and help ,Keith
