Full Length Vs. Stock Axles
SaddleUp
Vancouver, WA
GRN_MEANIE said:
Meaning That I Would Have To Replace More Wheel Bearings? I'm Gonna Go 35 Spline 9" In The Rear, And Figured I Would Eventually Go W/ The 9"d60 Front. Figuring That It Would Be Nice To Be Able To Swap Center-sections. But I Haven't Seen Much In The 9"d60 Axles.
A full floater gives you the option of just pulling the axle without worrying about further damage after an axle breaks. With 35 spline alloy axles you are not going to need to worry about breaking axles though and there are other advantages to the 35 spline 9" that outweigh the disadvantage. That being that the gears are stronger in them and the ground clearance is better. The 609 frontend is next on my list of big upgrades.
bigpappa
Gardendale Al
Skuzzlebutt said:
9" full floater
and if you need to, you can unlock the hubs.
Sure you can make a 9" full floater I have seen several articles and kits that do just that. I was speaking to there are no stock FF 9". For the cost to switch, I can get a FF60, change the gears and have money to spare.
