    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
WA Full width HP D44/9" for sale $2000
Status
Not open for further replies.
gearhead74
Tri-Cities, WA
Hey all I'm selling the axles out of my '74 bronco(going 1-Tons).
'76 F-F150 HP D44
-ARB w/Heavy duty airline
-Precision Gear 4.88 gears + overhaul kit/seals
-Napa gold/ blue-boot Ball joints
-all new rotors/bearings/rebuilt calipers/pads/hoses (~5k miles)
-Warn premium hubs
-Spicer 760 u-joints in stock axles
-Spare stock axles, driver/passenger sides, inner/outer, with new spicer 760 joints installed.
-Custom built Diff cover (lower half is 3/16")
-Wild Horses adj Trac-Bar #1231
-Custom 1/4" Trac-Bar riser(will need standard frame-side drop bracket on top end)
-Bullet Proof draglink/tie rod (over knuckle) Raceproof thick, stage 2 rod end upgrade
Currently the axle has stock bottom coil buckets/wedges (moved inboard to match stock upper coil brackets) ontop of Duff/Bloody Knuckle style radius arms. Comes with the back C-bracket (attaches to the arms) but not the arms.
'76 big bearing 9" housing
-Yukon 4.86 gears + overhaul kit
-Currie 9+ race case 3.250 bearing
-35 spl spool
-Jeff's Bronco Graveyard Ultimate 35 spline axle set
-Wild Horses Extreme Duty U-bolt kit
-Leaf spring perches moved inboard, pinion angle matched to a 3 1/2" lift
-all new drums/shoes/rebuild kits (~5k miles)
-Custom traction bar, 1 1/2" .250 DOM, FK 3/4" rod ends (3), mounts behind T-case on custom crossmember in the front(need to build your own), rear mounts: one near bottom of axle, one 2" above axle tube, near pumpkin.
Have reciepts for everything but balljoints/u-joints/brake stuff, I could probably find them if I dig deep enough, have 3 large envelopes packed full of reciepts over the years.
Looking to get $2000 for the set.
Call or text is the best way to get ahold of me. (509) 366-5580 Located in Kennewick, Wa 99336
Status
