full width king pin d44 or eb d44
Colman
Houston
I already have a rock crawler cj so not doing that with this bronco but
I have a full with drum brake d44 from a 66 truck appears to be 3.54 gears drivers drop KING PIN low pinion drum brake. i have the chevy parts to make it disc brake i could use on either axle. the wedges are also weld on so i could move them to work with the spring hangers on the frame. i'm looking for thoughts. i'm probably gonna go with about a 3.5" lift and 33's but maybe 35's.
The question is would you go full width or use a eb bj d44. I have both.
I have a 200 six i'm going to use for now with stock trans till i get everything together and driving then at some point down the road i plan on doing a v8 swap but who knows when that will be and the fresh 200 from a mustang only has 300 miles on it.
C
Colman
Houston
i can cut down the kp d44 to eb width now the question is the novelty of the king pin worth it. I know they are stronger than ball joints and there were a few rare eb d44 kp axles that went in as dealer warranties and what not so that is kind of cool.
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
Closed knuckle kingpin D44's are rare and not very strong. When guys refer to "king pins" being strong, they mean Dana 60s.
Ball joints are plenty strong. Stick with the EB axle for ease and parts availability.
If you feel the need to do some actual cutting and fabricating, find a 76-77 HP F-150 axle and narrow that thing. You could also do a 73-75 as well but they are drum brake.
C
Colman
Houston
this is open knuckle king pin low pinion d44. i didn't know the axle existed before i saw it.
welndmn
Can you get some pics?
I thought those were all closed knuckle?
I know the f250 got kingpin 44'ss but I think those were high pinion.
broncnaz
Fords open knuckle D44 started in 66. Id pass on using it especailly if its a low pinion. Supposedly all the early low pinion FW axles also had closed knuckles. Ford used closed knuckle low pinion D44's up to 76 on F250s. While the F100/150 got open knuckles and high pinions. But you never know sometimes a few oddball axles get out of the factory. One of the benefits you want with a full width is the high pinion. But still those early D44s have no real benefits small axle shafts, still have to convert them to disc brakes, And the king pins they have are probably not as strong as ball joints.
If your only going to do about a 3.5in lift and 33's with a maybe for 35's. Id probably stay with EB width axles. Later on down the road if you feel the need or go with a taller lift and the larger tires you can swap in the FW's
C
Colman
Houston
Well I'm slightly retarded. It is hp. And I just looked and the long side inner shaft ujoint let loose and the ears are toast.
broncnaz
You can use later model F150 axle shafts in it they are the same lenght. Plus you get a bigger ujoint. You will probably have to clearance then spindle hole to get them in tho.
Honesly you can usually pick up a 76-79 F150/big bronco axle for less than its giong to cost you to upgrade the axle shafts and convert to disc brakes.
C
Colman
Houston
I've already got the disc brake parts to convert. I guess I will use them on the eb d44. I bet I have a shaft in my spares pile that would go in the axle. Random shafts from over the years.
