Fullcab to Halfcab Mod
73azbronco
That is probably one of the coolest mods I've seen here in awhile.
njy229
njy229
Newbie
Thanks, I've been thinking about attempting this for years and finally started on it as a winter project last year. Nice to not have an old Bronco top taking up space in the yard anymore too.
njy229
njy229
Newbie
Getting it fabbed up nice. Have you thought about adding a CHMSL (brake light) to it?
Actually I have, to the point where I was shopping online for one. All of them were designed to mount to the outside of a metal panel and I was looking for something to mount to the inside so it would be flush with the panel. I also thought about cutting a design or the Bronco script into it and having a brake light behind it to light it up. I don't want to get carried away and make it gaudy though.
76YETI
KC METRO
On a side note, your bronco has a great stance...Care to elaborate on suspension/BL, tire size??? Thanks.
njy229
njy229
Newbie
When I was young with no back pain I installed the KbarS 2.5" suspension lift pictured below and a 2" body lift. Now that I'm older with back pain I replaced the vintage KbarS springs with the 2.5″ 11 Leaf Springs and 2.5" Progressive Rate Coil Springs from James Duff. Also have one Eibach/Duff MS2020 shock per tire now. Still have the body lift too.
35x12.50 BFG All terrains for tires.
nvrstuk
PNW
Turned out great! Nice work.
Wish I would have seen this earlier and followed. I built a half cab out of a half cab. It had been crushed and I made new sides and made them longer for more footroom with bucket seats. No back window as my 6pt cage needed to go thru like you did. I used BMW windscreen material for the back.
Bending the rear corners kinda like you did. I have pics somewhere showing 6 large 1" pipe bar clamps and a dozen welding clamps on each side to get the compound curve. Took forever!
This is from tonight as my daughter and I are running the Rubicon & headed that way tomorrow. You can see the sides are a bit longer and the back windscreen.
Built this around 2010 as I was year round topless for a dozen years prior here in snow country. Drove it almost every day.
njy229
njy229
Newbie
Damn that looks awesome! Gives me some motivation to do some bodywork and throw some paint on mine. I've been procrastinating because I want to line up the doors before doing any bodywork on the top. Door alignment is one of the most frustrating things to do for me.
I thought about using clear vinyl (with holes for the rollbar) as a rear window but this Bronco is basically retired from wheeling and is a nice weather cruiser now so I'll just leave it open. I still have to decide whether or not to add a 3rd brake light too.
nvrstuk
PNW
I have looked for years for a flush mount (similar) 3rd brake light.
I have looked a lot on big road bike sites also but can't find the one I liked about 8yrs ago on a big Hog.
Keep on it! I like what ya did and you'll love it for years to come! :)
njy229
njy229
Newbie
The plan was to do bodywork on the top this past winter in the garage but after I realized the dust would be out of control I used that excuse to procrastinate until the weather was nice enough to do outside. We had decent weather the other weekend so I got to sanding. Going to need to do a little welding in the corners to fill up some of the bigger holes then I'll throw some body filler on.
bronkenn
Bronco Guy
Southeast Ohio
That top is coming out nice. While you are doing some body work you could make a rear center high brake light. I built one out of fiberglass to match the profile of the roof. It is not too gaudy but is very noticeable when the brakes are applied. It has small round LED;s in it.
njy229
njy229
Newbie
I thought about adding a 3rd brake light and might down the road. I'm at the point where I just want to finish this project because it has taken so long and is cluttering up the garage. The back piece of the top that drops down a bit is screwed into the top and can be easily removed so it will be easier to cut a hole later to add a light. Your 3rd light looks great.
njy229
njy229
Newbie
I think I'm pretty much done. The bodywork isn't the best but good enough for a full size top that I was going to scrap due to rust. I'll have to take another pic after I wash the winter dust off the Bronco.
