I have read through most of the old posts on the subject but had a couple of questions. How long are guys letting concrete cure before coating with epoxy? Are there any new updates/opinions on the epoxy coatings available to the consumer? Thanks!
Also, if you don't have a vapor barrier between the slab and dirt nothing will stick for very long. Moisture will wick up and delaminate the "paint".
I have used a silicon sealer on my floors and it works great. It's almost like water in the can, pour it on, mop it around, let it soak in and done. It keeps the oil from soaking in and staining the floor and doesn't burn when welding or cutting on it. The stuff I have left is about 40 years old so I don't know if it is even available anymore. Some tree hugger probably got it outlawed since it works%)
Jim W.
Alot of folks over at garagejournal.com say they wish they NEVER did the epoxy flooring.
I would bet that sealer is very similar to grout sealer for tile. Description and application sounds basically the same.
It does have a vapor barrier and is heated (radiant). Will the heat make a difference in terms of how the epoxy will hold? I have done all my garages with radiant in them but have not done epoxy before.
