Have had issues with surface rusting on tools, reloading equipment, etc in my garage for a bit and have been trying to combat it recently. Got all the pool chemicals out of the garage and stuck a digital thermometer/humidity gauge on the garage freezer to get a baseline which ranged in the 75-80% humidity mark. Here in Houston we fortunately are far enough away from the coast to not deal with salt but humidity is just a fact of life. Most days it feels like you jumped straight out of a hot shower without drying off and just put your clothes on. My garage is in a reverse L shape (considered a 3 car garage, but really room to park 2 cars with more depth on one side for more storage/tools/hot water heaters). The laundry room also backs up to the extra storage area inside the house so I am sure the washer/dryer running non stop up against that wall doesn't help matters.
For a short term solution, I bought a portable dehumidifier rated for about 4500sq ft and stuck it in the garage to see what it does. Running continuously over two days I was able to pull the humidity level down to 35% in the garage which is nice. The downside is the bucket fills up with enough water after 12-24hours and the unit auto shuts off until its dumped...not a huge issue but I am sure it will get old over time. This should solve humidity issues for a while during teardown and construction of the Bronco, and keep things at bay but longer term I know I am going to need a better solution.
What do you guys do for a longer term solution? In wall dehumidifiers? Etc etc?
