- Nov 3, 2003
- 49,366
Hiss can also be coming out. Gotta' feel for it rather than use the word "hiss" I suppose. Could go either way.
A pressure buildup can be easily caused by just ambient heat expanding the gas inside an unvented tank. Normally a return line should not do it by itself, because theoretically less fuel is returning than going back in. So not a fuel buildup, but more likely a heat buildup.
Only takes a few degrees to get a result. Especially when the tank is more full.
You can easily evap it with factory parts. Better still are newer factory parts that mimic the '76 and '77 models. Those charcoal canisters, or ones very much like them, can still be bought because they were used up into the early nineties at least. Anything newer than that is likely too exotic for our uses and needs a computer to control them.
But anything from the late seventies to early nineties in the rectangular plastic tank of about a quart capacity should work if it's got two large ports and two small ports. Or a small and medium port.
Lots of discussions about it here, but basically any stock tank from '70 and up should have the vent tube fitting you can use. You can mount the new canister to the firewall and run a hose from your tank's vent to the small port on the canister. Then run one of the large ports over to the air cleaner housing. Leave the other large one open, or better still use one of the standard "mushroom caps" that were there originally to keep debris and moisture out of the canister.
If your '76 is original it should still have a steel main tank with one, or two small 1/4" or so fittings sticking out the side, just in front of the main filler neck opening. \
I'd be interested in seeing some pics of yours to see if any of the original stuff is still there. And whether it has one or two of the fittings.
Is there anything like a charcoal canister mounted either up on the passenger side firewall, or a metal can mounted to the passenger frame rail just under the footwell?
