clintonvillian
So,
Someone gutted the EVAP system on my 71. I put on a vented gas cap when I installed my new tank.
With the new tank, I notice a "whoosh" every time I open the cap. The tank is pressurized from the heat and vapor. I guess the old tank had a leak, because it didn't do this.
So, I have been running new fuel lines, new fuel pump, etc. I noticed when the fuel line was unhooked, the pressure was pushing fuel up the pickup tube and out of the line.
I really don't want to drop the tank until I need to (at which time I will definitely install a check valve and charcoal canister.
Does having the system "pressurized" cause any problems?
