I have taken a welding class that was about 70% arc (stick), 20% gas (mostly cutting), and 5% MIG. Why only 5% MIG? Because it only took a couple of inches of welding to lay a bead as good as I could do with a stick welder.
I just got a welder. Nice Millermatic 175 MIG welder. I just like the point and squirt of MIG welders. The gas shield is great for clean up. No chipping the slag off.
Gas takes a lot of practice, but can weld almost anything. TIG is basically an electric version of gas welding. I would like to have a TIG welder, but I often don’t have the 3 body parts needed to run the torch, filler, and the foot feed. I am often welding while wrapped around a part balancing on one foot. That makes the one hand point and squirt welder so nice.
As far as doing body panels, expect to warp them unless you practice. Use gas shielding and use the thinnest wire you can run in the welder.
Practice on something else first. Orders up some mandrel bent tubing, cut it into pieces and weld it together for a custom exhaust first. It is cheaper then body parts. If you screw it up, it’s easy to scrap and start over without losing the entire project.
If you can get a welding class at a community college, great take it. You can burn up enough material in that class practicing to pay for the class. And you will have somebody telling you what you are doing wrong, before you are set in your way of doing it that way.
As far as the gas welder goes, I hope you got a cutting tip. Then it’s worth it. Nothing heats metal so you can bend it like a torch….
