Mac2Night
- Aug 10, 2005
- 2,199
So, after bragging over in the chat forum about my successful carb rebuild yesterday, I notice this morning driving to work that my carb gaskets are still slightly leaking on the side of the accelerator pump and on the top plate gasket.
I snugged the screws as much as I can without stripping them and still they "weep" gas in two small areas. The leak at the acc. pump housing plate isn't really a leak, it "spays" a fine stream of gas when I hit the gas pedal hard to speed up. I noticed a hesitation/stumble in my acceloration coming up a hill and it prompted me to pull over and check things out. This is when I noticed my continuing problem. I took care not to knick the housing of the carb during my rebuild, BUT it appears there was some knicks in these areas from the PO which is probably why these areas are not sealing well.
My question is this: Can I use some type of tube gasket sealer to stop this leaking? If so, what do you recommend?
If not, what should I do to get these areas to seal?
Thanks in advance for your help.
