Gauge cluster refurbishing
fallingdown
fallingdown
NicksTrix
i just got a few back that i sent in for service. i had chased these things for way too many hours trying to get them to work right.
they came back looking great and got their issues repaired. it's great to have this easy option now to get your old speedo heads tuned up and help support a standup bronco guy.
thanks!
fatboy4211
Ennis, TX
Kevin. When you get a chance. Would you call my classic car mechanic at 9728752741. His name is Shane at his shop between 9-5 cst. He has some cluster work for you. Thanks
fallingdown
fallingdown
Thank you David I just spoke to Shane. I really appreciate the referral.
DuramaxC10
my fuel gauge on my truck is reading empty when there is still 6 gallons in the tank what is causing that to happen
fallingdown
fallingdown
It could be several things:
1- Bad ground.
2- Bad sending unit.
3- Bad fuel gauge.
4- Fuel gauge needs calibration.
If the other gauges are working I would say that your IVR is fine. If you have a stock gas tank and your fuel gauge only reads half you might have a bad sending unit. If you have an aftermarket gas tank and your gauge reads correctly until the last 6 gallons your fuel gauge might need to be recalibrated.
Unfortunately I just don't have enough information to be much help but I would be happy to take a look at your gauge for you.
