kinder
- Jul 18, 2009
- 127
Install went great and locker works great as well, but now I'm not certain about the gears. I always thought I had 3.50 gears since they seem to be the most common, the only thing that seemed odd was my rpm was higher than other posts I've read regarding gearing/speed/rpm combos. I wrote down the numbers from the ring gear: 4 30 73 DANA 18520 B3037 45-11 (and then etched 199) and I counted the number of teeth on the ring gear: 45 and on the pinion: 11 (matches the last set of numbers on the ring gear). So with all the numbers how can I tell if the ratio is 3.50 or ? I can also post my numbers for my speed/rpm/tire size combo after I run it to work tomorrow if that will help.
Thanks,
Kirk
Thanks,
Kirk
