Just for giggles, I caculated that the drivetrain combination specified with a 6000 RPM redline would have about a 170 MPH top speed...wow! Your HP/Torque numbers are impressive for a lifted, short-wheelbase, wheelie pulling machine. I've seen full-blown comp buggies get in trouble with less. I don't think you should be too worried about changing gear ratios with your current axles, but heavier duty axles with significantly lower gears (4.56) would be a good idea. The 9" can be built the live but the D30 or D44 won't be too happy if you ever use the skinny pedal in 4WD.
