NC-Fordguy
Guys,
I would like to hear some suggestions on what you all think would be a good upgrade. I just rebuilt the C-4 tranny and noticed some wear on the front axle gear ring. So I figured since it's time to replace the worn out stuff I need to make up my mind.
Current setup is a 302, bored 30 over essentially stock, c-4 auto, 33 in tires with 2.5 inch suspension lift, cut out fenders with the stock 3.50 gears
The 74 Bronco sees it's share of off roading with some daily driving thrown in. I wanna keep the ability of driving this thing to the trails rather than having to trailer it.
After the 33 in tires wear out. I'm thinking about going up to a 35 in tire.
What gear ratio do you all think? I'm thinking about 4.10, but 4.30 would be better when I get around to putting on the 35 inch tire.
Should I upgrade the axle shafts to 31 spline when I do the re-gear($ is an issue) Any of you guys running 35 in tires with the 28 spline shafts?
While I'm in there this seems like the time to install a detroit locker in the rear.
Thoughts or suggestions?
Ed
Ed
