Glass Bodies
Bluebolt
Benton LA
Hey Broncodesign can you put out some more information on your stretched tub? is that 12" of stretch? Has anyone built one yet? Can you modify a stock frame or is a custom one going to be needed? I have a 66 frame with title I am saving for a long term project and am considering using your body, either stock or stretched.
sxr800
Question for sxr800: What sort of body/fiberglass work did you have to do? Any pictures?
Certain areas like the tailgate jambs i don't think can be produced in fiberglass exactly the same as metal. So you don't have the clearance a factory metal body has for the tailgate mounting hardware. You need to cut through the glass to get to the metal framing for hardware mounting purposes. Not much but you will want to patch this and it takes a little thinking outside the box. The front fender seam where it meets up to the door inserts needs some fine tuning to close the seam a bit and I'm going to fiberglass in some backing material on the inside of the door inserts for bolting too. Once you close the inserts up you won't be able to get to the inside to put a wrench on anything if you want to unbolt the fender for removal. I'm planning (fingers crossed) to work on the dash this weekend. I don't want to just fiberglass the dash in permanently so I will be reinforcing the areas that will be bolted (like the factory locations) with backing or nuts glassed in on the opposite side. Kinda think about it,, I will try to put together some pictures this weekend on what we have done and plan to do.
ep67bro
ep67bro
Bronco Junky
Easton, MD
I have been thinking about the glass body, but I want to keep the steel doors, tailgate, Front grill, and steel windshield frame. Maybe steel front fenders, any issues matching the steel to the fiber glass?
I don't care for the sound and feel of the glass doors and tailgate, and I prefer the look of the steel grill.
jamesf7278
Salmon Arm B.C
mine is steel fenders, doors, grille, hood, windshield frame. all fit with minor tweaks here and there. I did have to spend a couple days on body mounts for the door fit but that's still pretty easy work. if I had to do it again I think I would go with fiberglass fenders too, just for rust sakes.
englewoodcowboy
Lick Creek Restorations
The only wish I have of the BD tubs is to change the smooth rear bed. I hope one day they put ribs in it but other than that it is an excellent body and the craftsmanship is great.
BroncoDesignTN
The stretch tub is 12" longer than the standard bronco tub. The extra is added between the striker post and rear wheel opening. The idea is for a stock frame to be lengthened by 12". All of the front and middle body mounts are in the same location as stock. The rear ones will be 12" further back.
There has been one stretch tub sold, before we bought the company. Mike sold it to a guy in Canada. I'm not sure if he has finished his project yet or not...
Here is a couple pictures of the stretch tub.
Let me know if you have any more questions.
BroncoDesignTN
As James mentioned, you can certainly use your steel parts. Mike designed the tubs and fiberglass parts to be able to interchange with their steel counterparts, for the most part anyway.
We are just launching our fiberglass tailgate next week. I think you will like the sound and feel of it! It is solid and reinforced with a steel tube along the bottom and top! Pictures to come soon...
