I wanted to ADD one to mine and just make it a reserve tank.
install a momentary switch wired to a cheap electric fuel pump that pumps fuel thru a large 3/8"+ line to a vent in your main tank. This way when your main tank runs down, you can just hold the switch (not an on/off switch because you will forget its on and it will burn up the pump) and pump the gas from the AUX tank to the main tank. And the best part is you dont have to deal with high pressure lines, return lines, or a multi-position fuel slector switch! And it would be easy to wire/plumb. You could even add a valve that lets you pump the gas into a container and fill someone elses rig... be the hero!
...or if you are not worried about having extra fuel, you can ditch it!
