I'm running a 351w with a carter 4 barrel and ebelbrock manifold and was able to put a k&n filter on my 74 fits fine. Sorry I don't have parts nr, but bought it at autozone. Hope this helps.
Stay away from foam filters ... they are even more restrictive than paper filters. As air flow (RPM) increases, the "foam cells" actually compress and close-up restricting the flow of air. K&N is the only way to go, period.
[quote author=dpm77 link=board=5;threadid=9948;start=0#73503 date=1034620723]<br>Does K&N make a stock size replacement, one that would simply replace the fram over my 302 in the oem cleaner case?<br>[/quote]<br><br>They do, the PO installed one in mine.<br><br>Check this out:<br><br>http://www.knfilters.com/appinq.htm<br><br>Jerry<br>
