Got any pics of aftermarket extra capcity gas tank?
1970excursion
Looking into the BC Broncos 23 gallon rear tank,
Anyone have pics of this one or similar installed.
Would like to know how low it hangs without a body lift.
Buckeye Rob
Hurst, TX
These aren't the best pics but I have TBP's 23 gallon tank with no lift. I'll take a picture from a lower angle tomorrow.
There was a thread in the last month or so with the same question where some had posted up images of theirs. There should also be dimensions as well.
Sorry, don't have a direct link for you.
WorkerBee
Northern CA
This is the one that I built so it's not actually apples to apples. I made it a little wider but a little shorter than the vendor's tanks so it wouldn't hang down really low. Mine is about the same size in volume.
It's just deep enough to adequately house the explorer pump/sending unit. I have a 1" BL also. Mine's very similar so maybe this will give you an idea.
C Saporito
I wont have a good pic with the body mounted for a couple weeks, but here's mine mounted kind of high. It will have a 3" body lift.
Teal68
Inlet Beach
If I get mine in this weekend I'll take pics for you. It will be stock height, no body lift.
If you're a wheeler, you can also add a skid plate. Of course, the tradeoff is that a skid plate would hang down slightly more. But the added protection is possibly worth it too.
