MikeEB
fireman1749 said:Hey man nice buildup. Unless you have reverse cut gears or a Currie High Pinion rear, you have it upside down. 9" Fords are not high pinion.
Currie High 9 ;D
MikeEB said:One more quick update just for Patrick ;D HAHA, thanks for catching that.
BlackHorse said:You might as well turn the shackle bolt around now, the head should be on the frame side. Just trying to be helpful. Peace It's looking great.
PDXBronco said:I think it is a safety thing...if the nut comes off, the bolt stays in keeping the spring in place (frame blocks it from exiting). If the bolt is from the outside it can come right out and make for a precarious situation. I think the double wrap in the front is a safety thing too. I put mine on backwards too I was a little bummed that I had to unbolt all that crap to flip them..ugh.
MikeEB said:Huh, I hadn't considered that. Thanks alot for tip guys, I suppose that makes sense and it doesn't hurt anything to just switch it up.
Thanks,
Mike
Blackhorse,joe said:where did you get your High 9 at?
Why cant a guy just flip a stock rear end??:?
daj said:Because the rear would be going in reverse and the front would be going forward. You would tear the old girl in half, and if in two wheel drive you would only have 1 gear forward and. depending on your gear box, 3 or 4 backwards. ya think?
dj
