Got the 77 Line-xed today
66ALRIDE
Just BIP It!
Dothan, AL
Here are some pics of Lockjaw's 77 after it was sprayed by Line-x.
66ALRIDE
66ALRIDE
Just BIP It!
Dothan, AL
As far as prep work, it was completely sandblasted, scuffed with 80grit sandpaper and then sprayed with epoxy primer. Then they scuffed it again and sprayed it. They did an excellent job on it. The underneath is sprayed with line-x also. The engine bay will be alot easier to clean, and plus wanted the rust protection.
Tito
CB Fire Starter
Bakersfield, CA
Be careful around the brake fluid when putting things back together, it will lift the line-x from my experience.
Looks great!
66ALRIDE
66ALRIDE
Just BIP It!
Dothan, AL
It's actually on an old frame that we made a rotisserie out of.
deltarat
Drew,Ms
That looks great! I can't wait to do mine. I am going to do the bumpers too. I hope to get it done in the next few weeks, especially after seeing yours.
66ALRIDE
66ALRIDE
Just BIP It!
Dothan, AL
The guy that sprayed it had a fullsize Bronco and had the interior done. He had also sprayed the door panels, plastic trim, and part of the dash. It looked good, but I would think it would be a pain to clean and the door panels would irritate your arms. But I will say it's some bad a$$ stuff.
LockJaw
Thanks for the comments. And thanks to 66ALRIDES for helping me get this far. For those that dont know check out 66ALRIDES youtube profile. The 77 tear down is the same as pictured here.
trailpsycho
When I had mine done; it was recommended to take the color underneath the Line-X. Any reason why you guys didnt? You will love it. It cleans up pretty nice with just a pressure washing. Speaking of which...I need to clean mine up.
I hope that you had them tape the door post areas where the front fenders mount as they wont fit right with the layer of liner on them. We did take this into account on mine and I still had to clearance a few spots (where the door post meets the rocker. We also shot the inside of my front fenders and they had to be stripped along the edge so that the fenders could go back on. Most of the tight tolerance areas were taken into account...but there are always some allignment issues, I suppose. Good luck.
66ALRIDE
66ALRIDE
Just BIP It!
Dothan, AL
On the ones we've done like this before, we've just backed taped with fineline tape and have never had any issues. As far as the door post, those areas like where the fender meets the rocker and such were not sprayed. They were taped up except for the top of the inner fenders. On top of the inner fenders is just a light coat of bedliner spray, usually don't have a problem but if so all it takes is a little grinding with a flapper wheel.
Thanks for all the comments so far, I think Lockjaw is finally seeing some progress on it.
