I've had a Grant steering wheel on the Bronco since I bought it in 1990. Recently, I changed the TS switch out (the one I purchased in 2001 or so was broken) and now the horn is on all the time. I can get it to shut off by not putting the wheel on all the way but as soon as I snug it up it trips the horn relay. It seems like the adapter is pushing on the TS switch too much. The pic below shows about where it should be but if I try to install it there the horn goes off as soon as I push on the wheel. Never mind the wheel is loose since it is not seated on the taper. It's almost like I need the shaft to come out a 1/8" or so but I am not sure if that is even possible.
Thoughts?
Thoughts?
