I could use some help on my H4 headlight conversion kit I bought from Tom’s Bronco Parts. I installed the upgraded wiring harness, which connects to the old harness and installed the head lights about 3-months ago.
The system worked great until about month ago and the lights would only work on high beams. All the other lights on the rig worked perfectly. I turned the switch on and off several times and the low beams would finally come on. This happened a few times, but not every time.
A couple of days ago it happened again, except turning the light switch on and off did not work. The low beams would not come on. Turning the high beam switch on and off did not work either and the lights work on high beam just fine.
I called and spoke to a TBR tech. He suggested maybe replacing the the high beam switch. I checked the 2 inline fuses, but they look good, but I will change them out anyway. He suggested testing the system with a meter from the headlights back. I’m not sure what I would be looking for. Obviously, there is power going to the headlights, since the high beams and all other lights work. Also, I replaced the light switch about 6-months ago and it has always worked.
Anyone else having problems with this system, or have any suggestions? The TBR people have always been easy to work with, but I don’t think the tech had any idea what was going on and was stabbing in the dark.
Thanx!
Thanx!
