Hand Pump Recommendation Please
bizarrocolin
Redlands-IE-So Cal
Does any one have a recommendation for a good hand pump? I was using a cheap one to fill up the transfer case, and the output end popped out mid stroke. It did a nice oil money shot across the garage.
Thanks in advance.
blubuckaroo
Grease Monkey
Ridgefield WA
I've done that too. %) I just changed all my gear oil and used the quart bottles with a tip. It worked a lot better than the plastic pump. I also found that the same tip would fit the quart bottles of Valvoline Racing Oil that I use in the transfer case.;)
JSBX
I bought a pump from NAPA that has a lid with it that fits a 5 gal. bucket and it works better then any thing I have ever used. It is made heavy duty has a good hose on it. I believe Tractor Supply has them also.
nickgp
I'm looking for one too. The one I got from Auto Zone came apart on the second use. Nice super slippery Polaris diff fluid all over the floor. Arg!
