topless
Sounds just like my project I picked up a 67 1/2 cab servivor came with a wagon top also. just getting it running well has been a job in itself. I changed all the fluids and coolant it had the wrong fan so it would get hot around town and on slow trails a proper fan and a mustang coolant tank to replace the corroded tank works great stays at 180 all the time ,new brake and spring kit to make it stop straight , tires cause it needed them, suspension bushings front and rear I used the stock rubber type in the front but now I wish I would of went urethane, the stock rubber ones have already started to rot in less than a yr . now I'm driving it and fixing the little things, took apart the vacuum wiper motors and cleaned and lubed them they work great wish they were timed but hey its a EB, installed the doors and top seal kit ,lots of blaster lube and silicone spray for sticky parts and squeaks ,it is getting to be a nice driver and easy trail rig ,summer is almost here and a few camping trips are already planned.also it is getting to use the tow bar for a trip to Alaska this June. and with good research I'm only 400 bucks into it so it can be done inexpensively, have fun with it and drive it
