Hard top repaint options
Schreiber
Huntsville, AL
Looking for input from the community on repaint options for paint that's flaking bad. I've never painted anything other than a bedroom, so auto paint is new to me. I'm inclined to do a rattle-can Wimbledon White. What are my lowest cost options? Primer, paint, etc? Links to how-to's or whatever are welcome. Thanks.
current condition of my hard top
wesleydax
i would start by chemically stripping or have it media blasted. then use a good etch primer followed by a top coat of color. only draw back with blasting is you will need to remove the glass.
pcf_mark
I have painted several cars and my Bronco was the latest. I have to say the hardtop was the most difficult. It is easily the largest part, consumes the most material (paint etc.), wavy, perfectly vertical surfaces that run easily. If you are going to do it do not undersell the complexity and time consumption.
That being said...I would strip it to bare metal using a chemical stripper (you will need about a gallon get it at Home Depot), 180 grit sand it, do your body work, epoxy primer (2 qts), wet sand 400, fill the seems in the drip rail with fuzor (2 tubes) spray on single stage color (1-2 quarts depending on coverage). You will be $200 in material before you know it including the rear hatch.
Rattle can will look like poop. You would be better off sanding what is on there and getting a shop to hose on some white. It may not last forever or look the best but may cost about the same and be done quicker.
I took all the glass out very carefully and re-used the original gaskets! Saved over $100 in gaskets too!
allenfahey
What Mark said but to clarify a few things and a few tips. These steps/tips are for just the outside of the top. If you are doing the underside I would tackle this a bit different. For the stripper... use some 80 grit and roughen up the paint a bit. That will let the stripper get underneath the paint and it will require fewer coats of stripper. You might not get 100% to bare metal but that is OK you can sand it off later. After the stripper is on there and stops bubbling use a body filler applicator to scrape the scale off. After the final application of stripper you need to clean it off. I don't like using water because of flash rust. I use thick rubber gloves (SAS 6604) and scuff it with a red Scotchbrite pad and lacquer thinner. The lacquer thinner will dry up the stripper and the scuff pad will help remove the scale left from the stripper.
After you wipe it down with a final wash of lacquer thinner wipe it dry and sand it with 180 on a DA. Sand the rest of the left over paint on it. The gutters will have factory seam sealer in there and should be rock hard. Scrap all of that out using a screw driver, wire wheel, or what ever you have. Then sand the gutter with 180. If there is any rust spots they need fixing and treat the rust with metal conditioner. I like to use Dupont 5717S.
You then have a choice to use epoxy primer or etching and 2K high build primer. Whichever you choose make sure you get a TDS (technical data sheet) and pay attention the the substrates. It will tell you everything you need from substrates, mix ratios, to dry times. I would pick a primer that converts into a sealer. I would also pick one that uses the same hardener that is in the primer as it is in the single stage or the clear, depending on what you are going to use. By using the same hardener many times it's cheaper because you are buying fewer different materials. Same goes for the reducer that is in the primer, sealer, single stage, and clear if you are using base/clear. (All base coat has different reducer than the other pruducts) If using base coat ask the paint shop jobber to reduce it for you. No need to pay for a bunch of extra reducer.
After the primer drys spray a guide coat on the body work areas and block sand any body work with 180 and re-prime those body areas. Apply guide coat on the whole thing before sanding the rest of the top with 400. Dry on a DA is fine. Then scuff it with a red scuff pad. For the gutter use a self leveling seam sealer. The good seam sealers are two part ones that use a double barrel gun which you can usually leave a deposit at the paint store and borrow it. 2-3 tubes will be needed. Make sure to purge the mixing nozzle of the seam sealer. Also make sure the top is level! Let that set a while and dry.
Use prep solvent, also called wax and grease remover using a lint free rag to wipe small areas at a time and a few other lint free rags to dry as you go. Tack it off with a tack rag. Mix the primer that you got as a sealer following the TDS. Apply it and let it flash off and then apply your paint. Don't mix brands of sealer, paint, and clear. They all have to be 100% compatible or else you risk the chance of paint failure.
It sounds complicated but it really isn't. I really need to to a full paint how-to writeup for the tech guide.
bronconut73
What Mark said but to clarify a few things and a few tips. These steps/tips are for just the outside of the top. If you are doing the underside I would tackle this a bit different. For the stripper... use some 80 grit and roughen up the paint a bit. That will let the stripper get underneath the paint and it will require fewer coats of stripper. You might not get 100% to bare metal but that is OK you can sand it off later. After the stripper is on there and stops bubbling use a body filler applicator to scrape the scale off. After the final application of stripper you need to clean it off. I don't like using water because of flash rust. I use thick rubber gloves (SAS 6604) and scuff it with a red Scotchbrite pad and lacquer thinner. The lacquered thinner will dry up the stripper and the scuff pad will help remove the scale left from the stripper.
After you wipe it down with a final wash of lacquer thinner wipe it dry and sand it with 180 on a DA. Sand the rest of the left over paint on it. The gutters will have factory seam sealer in there and should be rock hard. Scrap all of that out using a screw drivers, wire wheel, or what ever you have. Then sand the gutter with 180. If there is any rust spots they need fixing and treat the rust with metal conditioner. I like to use Dupont 5717S.
So you think that it only "sounds" complicated. You are definitely a "real" paint guy. My head is still spinning. I will save this for my future re-paint. Thank you Sir!
sprdv1
REBEL
Just go on and Line X it, be done ;)
I seen it done before
73azbronco
Is there really any reason other than perfection that you need to get the inside of the top done other than rust control? Seems if you start etching and that stuff gets into the side seems you set yourself up for more problems than just controlling whatever rust there is. Wouldn't sanding/scuffing it and then applying some paint for rust prevention and going with a headliner be good enough? Or are headliners out now? Just asking, not criticizing in anyway..
Lennardlector
Virginia Beach
Scuff and shoots are fine, locking off the rust with new paint is fine. But the rust appeared there somehow. Diving into the inside of the top generally means a complete dissasemble and I always like starting from scratch so I know that everything is sealed. Linex or whatever undercoat provides better protection and sound deadening properties in addition to a headliner. I would hate to throw money at a liner and discover it thrashed due to a leak because I chose to go quick and cheap on a job and put new paint on hardened and cracked sealer.
