It could be the thermal coupler in your head light switch TMC. You have to replace the whole switch to find out, but it's not that bad. They are only about twelve bucks and in stock at most parts places.
Disconnect the negative battery cable.
Remove the headlight switch control knob and shaft by reaching up behind the dash and pressing the knob release button located on the bottom of the switch, it's a little metal post. As you press, pull the knob and arm out from the switch past the two on positions to remove it.
Unscrew the chrome mounting bezzel on the outside of the dash by turning counter clockwise, there is a slot in it that will alow you to put a screw driver into and bang on if necessary.
The whole switch will pull loose from behind and under the dash. Disconnect the big wire plug assembly from the switch, you may have to pry them apart with a screw driver, if so be gental with it.
Now just plug in the new switch and follow these instuctions kind of in reverse.
My knob arm was to long, because I was missing a spacer, so I had to shim it with a nut between the switch and inside of dash.
Hope this does the trick and Good Luck !
