Header clearance with Cage arms.
jtyler4570
I just mocked up my cage radius arms and I can already tell they are definitely going to hit my driver side header with minor flexing. They are wild horses long tube headers. Has anybody ran into this? I assume my only option is for a different brand of headers or shorty headers. What do you guys think?
trailpsycho
The same question is being asked right now in the Chat section. Simple answer. Duff makes a Long tube header designed for use with their long arms (whihc means they will work with the near identical Cage arms). No other long tubes, that I have heard of in the last 4-5 yrs, will work. Shorties shouldnt be a problem. If your long-tubes from WH are new, maybe they will "exchange" them for the shorties. Good luck.
J
jtyler4570
Thanks trailpsycho you have my favorite bronco on this forum. It just sucks because there is really no other option other than to get different headers. I will have to weigh all of my options and decide where to go.
trailpsycho
Those be what I got. Very nice...a little tight to the PS frame, but manageable. They are also close to the PS inner fender and will melt your Line-X...ask me how I know.
Without a doubt, JTyler, someone will be interested in your headers. If they are 'new', see if WH will take a trade-in on them. Etiher way, if you make the deal sweet enough someone here will undoubtedly take them off your hands. I had a local Bronco-Bro who took my L&L headers and my 2 yr old exhaust (true duals with SS Flowmaster Delta 50s) off my hands...we both got a deal. He was installing the same tranny I had (in fact, my whole 'old' drivetrain), so it was all going to fit anyway. Sometimes things "snowball" between planning, the budget and execution.
Thanks for the compliment, I appreciate it. Good luck with getting it back on the road.
rtreads
...I have the same problem. Rather than build a new exhaust system to fit the shortie headers, not to mention the $500 for the shorties, I am going to cut the 2 lower tubes and rework them so they are out of the way. Basicaly bring them up tight to the other 2 tubes. I'm not worried about flow, and equal legnth.... its a damm bronco, not a 500HP+ drag car. The stupid thing is that both the headers and the long arms on my bronco are from Duff. Well at least thats what the PO said.
I am doing this next week. If your interested when I'm done I will post pics.
TBS-POPS
valley springs, ca
I had WH long tubes with cage arms on my rig and they will rub on the collector and the tube that runs out between the arm and the frame will get "clearanced" alittle but not bad. run them, I did and they will work.
I had to switch to shorties when I went full width cause the front drive shaft moves over into the collector on the long tubes. shorties work with everything, long tubes wont work with full width.all depends on what you want to do down the road...
rtreads
Good to know about the full width issues... I might be there someday
